| Message |
Hi guys we did a OBDII to OBDI swap and lost something along the way, The ac does not engage and it has something to do with the harness or OBD systems. The Z is a 96 with a 95 harness and ECU. When we finished there were 2 plugs left unhooked (brown) under the dash because the new harness did not have them, we are guessing that is the problem. The z is an Auto TT. I know i am not the first one to do this conversion so someone out there must of had this problem, help it is hot here!! the work was done by a pretty knowledgeable guy here in El Paso, TX but this was his first conversion so its a new problem to solve. just had the oil pump changed and the AC system charged it does turn on if you jump the relay but no fan activity, fan is good but gets no power
